Konica c284 with finisher jam J72-22
  • barber782
    • Aug 2011
    • 281
    Hi,
    Got a constant jamming issue on a fs-534 finisher ( tray 2 output).
    The paper enters the eject /sorter unit and jams on 2nd page in sorter.
    J72-22 is code recorded. Jams from all trays.
    Tested all sensors and nothing obvious yet.
    Any ideas?
    Sent from my GT-I9195 using Tapatalk
  • richmods
    • Aug 2013
    • 91
    Re: Konica c284 with finisher jam J72-22
    Originally posted by barber782
    Hi,
    Any ideas?
    I found this a few days ago searching for an answer to a different problem but may be relevant to your case. I assume this is an FS-534 finisher?
    http://www.copytechnet.com/forums/ko...e-wearing.html
    • barber782
      • Aug 2011
      • 281
      Thanks seen that post before. But don't think it's related to the problem. First page sits into the sorter unit, and then 2nd page stops as it enters the ejector unit
      • s817
        • Aug 2013
        • 13
        check the bridge unit guide part no. a3ep822100 guide/7 item 17
        as I have had a lot of these wear, generally at the rear and
        as the paper passes it can get delayed slightly thus bringing up a
        paper jam message, you will need to look carefully ( the part of guide that wears
        is the raised portion )as the wear doesn't have to be severe to cause trouble
        hope that helps
        • apollo
          • Mar 2008
          • 182
          Hi
          what was the fix for your issue i am having same symptoms on fs534 on km454e
          jam code j72-22
          thanks
          • barber782
            • Aug 2011
            • 281
            I think it was a mixture of things. Paper in the lct wasn't flat, causing a skew. Also replaced the paddle assembly above the staple tray.
            • apollo
              • Mar 2008
              • 182
              Will check tomorrow visit
