BIZ Hub 287
  • antone
    • Oct 2014
    • 344
    BIZ Hub 287
    While PRINTING to MACHINE B003 error code ....turn copier on and off.This code is a fax error....any one see this....i reinstalled firmware
    Sent from my SM-N920V using Tapatalk
  • Woxner
    • Jul 2011
    • 850
    Re: BIZ Hub 287
    install fax again following the steps
    • emujo2
      • Mar 2017
      • 1579
      Re: BIZ Hub 287
      1. You have the fax installed electronically, but no fax kit installed
      2. Fax has been removed, but still electronically installed
      3. Fax is installed, Service Mode is set correctly, but wire harness has a bent pin (common)
      4. Wire harness is inserted into Fax 2 connection
      5. You have FK 514 installed but should be FK 513 (similar in appearance)
      6. Dip switch is set to FAX 2 on fax board
      If none of these you might just have a bad fax. Emujo
      I re read your post after adding this and saw that this is occurring when printing..Does this mean you are using the fax driver? If so then the problem is somewhere else as all of the above would generate a B003 when MFP is powered on, not just during a print job.
