Konica minolta bizhub c353 error c2556
  • javier4065
    • Feb 2007
    • 251
    My problem is the following display says C2556 I enter service mode and I saw level history tcr ratio yellow ,black,magenta and cyan are 0% what can I do to solve it? Thanks in advance
  • habik
    • 2013
    Re: Konica minolta bizhub c353 error c2556
    Calibrate
    Image Adjustments》Gradation Adjust》Stabiliser 》 repeat each mode 3x (printout and scan it on glass).
    High Comp
    Gradation
    Resolution
    Sent from my GT-I9300 using Tapatalk
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • 5863
      you have to hit start, it prints a 4 color page and THEN gives a live reading.
      • javier4065
        • Feb 2007
        • 251
        Originally posted by habik
        Calibrate
        High Comp
        Gradation
        Resolution
        it can not do because the start buttom lights red.another adjusment thanks
        • javier4065
          • Feb 2007
          • 251
          How can i do this adjustment if the start buttom ligths red? Maybe there is another way.thanks
          • Synthohol
            • 5863
            what is the % of life on the consumables?
            • javier4065
              • Feb 2007
              • 251
              They are 50 %
              • Synthohol
                • 5863
                do you see a good brush (DV particles standing on end) on the mag rollers?
                is the toner path clear? can you boot in safe mode and run manual toner add?
                could just be a bad ATDC sensor on the IU.
                • paulrid
                  • Nov 2011
                  • 206
                  Try a system error reset first.
                  • avecosat
                    • Jun 2012
                    • 305
                    C2556 is a Yellow TCR sensor abnormally high toner density , first time I try to change the Yellow UI .
                    • javier4065
                      • Feb 2007
                      • 251
                      Thanks, brush and path toner are good,there are toner in cartridge, but I can not add toner in service mode,start buttom lights red,I See call service and yellow, magenta,cyan and black have several error codes, maybe can be a electronic card. How can I reset this code?
                      • javier4065
                        • Feb 2007
                        • 251
                        [QUOTE=javier4065;570404]Thanks, brush and path toner are good,there are toner in cartridge, but I can not add toner in service mode,start buttom lights red,I See call service and yellow, magenta,cyan and black have several error codes, maybe can be a electronic card. How can I reset this code?
                          • 14874
                          [QUOTE=javier4065;570423]
                          Install a new yellow IU
                          • avecosat
                            • Jun 2012
                            • 305
                            • javier4065
                              • Feb 2007
                              • 251
                              How can I do sistem error system?
