Konica C220 ADF jam 66-01
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I have a machine jamming with jam code 66-01 in the ADF (DF-617).
    It is multi-feeding intermittently....
    I have replaced ADF rollers, tried the separation housing spring in all three locations, replaced the separation roller torque limiter, blew out the sensors & pads and even added a couple of screws to the lift plate to increase the pressure at pickup....
    Any ideas to get round this without smashing it up?
    • 14842
    Re: Konica C220 ADF jam 66-01
    Originally posted by jonbonse
    Hi all
    Trim the mylar on the pre-separation pad back a couple millimeters and put the tension spring in the bottom slot,(least amount of pressure). that has always solved the multi-feeding problem for me.
