bizhub c35 firmware?
  • dvd7730
    • Jul 2017
    • 6
    I recently was given a bizhub c35 copier. it works great, but i've got an imaging unit replacement notification. It prints fine for now, but want to do the c35 life stop settings (bizhub C35
    Way to change Life attention message (Updated in July, 2013)). From what i read, there is no need to buy reset chips.
    the life stop pdf refers to the latest firmware update, so i need to update the firmware, but i cannot find it anywhere. anyone knows where to find the firmware and what the instructions for update are?
    kind regards
  • HitMan
    • Aug 2015
    • 170
    If the drum notification is there and it's working it may already have been set up to no stop for the life's?
    • dvd7730
      • Jul 2017
      • 6
      Re: bizhub c35 firmware?
      is there a way to easily check?
      • Don N.
        • Nov 2011
        • 409
        Last I remember, there are two FW, depending on the MFB serial #. Mine is running Ctlr FW A12130G0011005 Engine FW A12150G0020000. It's just a trade in IDK if/when the fw was updated. This fw shows on page 5 IU Yield settings: standard/long. I'd have to get the bulletin to remember where the stop/suspend settings are.
        • dvd7730
          • Jul 2017
          • 6
          i've got the following information (see below):
          my machine information shows:
          rom versie (rom version)Controller ROM-versie
          A12130G0064005Machine ROM-versieA12150G1090000Boot ROM VersieA12199G0040000ROM-versie displayA12120G0014805ROM-versie scannerA12123G0030700ROM-versie faxbordA12140G0011200
          it even shows one toner missing, while it is inserted?!
          anyone who can help me with firmware update for the life stop. the life stop pdf speaks of the following, but cannot find firmware updates anywhere. the life stop pdf manual mentions:
          "Update controller/ Engine FW to the followings:
          C t ll ontroller-FW (Mass-P d ti ) roduction): A121-30G0-1303-05
          Engine-FW (Special): (50G1) A121-50G0-1200-00
          (Mass-Production): (50G0) A121-50G1-1200-00
          any help is appreciated.
          • copier tech
            • 8138
            Update to the latest engine & controller firmware then change these settings.
            It does work even if your machine as reached "lif stop"
            C35 Life Extend.pdf
            • dvd7730
              • Jul 2017
              • 6
              thanks for your response, but i already found that pdf file. I'm new to the copier firmware scene, but i'm not willing to pay for firmware updates but thanks for your offer. so if someone has the firmware update software and is willing to share that without payment, let me know.
              • copier tech
                • 8138
                The firmware only extends the life of the image units, you will still need to replace them or change the chips. 🍟
                • dvd7730
                  • Jul 2017
                  • 6
                  that i understand. problem is, it still prints just fine with imaging unit almost near 0%. I feel no need to replace the imaging units until they are really worn out
                  • rrrohan
                    • Sep 2011
                    • 1977
                    yeah its a waste to change them before they are faulty. its like changing a toner when its only warning you its almost empty *looks at majority of my clients* lol
                    • copier tech
                      • 8138
                      Here's the firmware needed to extend their life.
                      https://mega.nz/#!FdMRCYJY!aMxRionI_uUjLM7Smn4emQSCHBOu1XM8T1k3bbH Aad4
                      • dvd7730
                        • Jul 2017
                        • 6
                        thank you! will give it an update tomorrow.
                        • gha369@gmail.com
                          The link above doesn't work. If you have the firmware could you please send me a download link? I'm having the same problem. Thank you!
