message add toner appears. I noticed that toner bottle doesn't rotate during adding toner procedure.
I checked and found that no gear at toner adding mechanism rotates. All gears are ok so solenoids. In recent past because i thoght that this mecanism was out of order i checked gears and cleaned colenoids . ALSO I tried to find out this mecanism works> it worked for 2 months and then this problem>
iS there any way to adjust it or i must replace it?.
