Bizhub pro 951
  • Gnazaret22
    • Jul 2017
    • 2
    [Error Code] Bizhub pro 951
    Hello everybody,
    I kind of new tech working with the Bizhub Pro 951/1052, and I would like to know if there is a trouble reset button for error codes just like in the mid size bizhub like Bizhub 652, etc.
    thanks.
    • 23010
    Re: Bizhub pro 951
    Not really. Some error codes will cause a DIPSW to flip, that needs to be set back, but it's unique to each specific code. Generally the answer is No, unless specified in the manual. There is no generalized System Error Clear like on the smaller bizhubs.
    The specific answer: Check your service manual in each case. =^..^=
    • Gnazaret22
      • Jul 2017
      • 2
      Re: Bizhub pro 951
      Oh ok, thanks for the info
      • waqasmailbag
        • Apr 2017
        • 23
        Re: Bizhub pro 951
        Originally posted by Gnazaret22
        Hello everybody,
        thanks.
        in bizhub 501 there is utility button for the troubleshoot purpose we restart machine while keep on pressing this button then machine automatically clear the error if that can work for you..
        • allan
          RTFM!!
          • 5462
          Re: Bizhub pro 951
          Switch 3 bit 1 to 0 not 1.
          Whatever
