C-0211 on C458
  • BluaboardTwice
    • Jul 2017
    • 11
    [Error Code] C-0211 on C458
    Hey guys ive been struggling with this code 2 months its happened 2 separate machines. Both machines are fairly new under 50,000 copies.
    Latest firmware that I know currently. Code will point to the bypass tray and possibly either a sensor or motor but Ive narrowed it down to paper feed drive assembly. Which because of the newer series of equipment is tough find (back ordered). I was really wondering how many if any have had success with this code replacing the paper feed drive assembly? Or any other fixes? Is this a problem Konica needs to get pro active about?
  • badaxe73
    • Jun 2010
    • 6
    Re: C-0211 on C458
    Did you find a fix for the 0211 code?
    I have a 658 with the same issue.
    • tech51
      • 846
      Re: C-0211 on C458
      You normally lose tray 2 and bypass when the drive unit fails.
      There is is a one way gear on the unit which is common to both trays.
      It it starts to slip and cause all sorts of jamming issues.
      Its quite a simple job to replace the assembly (if you can get one), or you could try stripping it down and cleaning out the gear.
      • antone
        • Oct 2014
        • 344
        Re: C-0211 on C458
        Vertical conveyance door...claws....hold door with both hands tight......door not tight enough
        Sent from my SM-N950U using Tapatalk
        • antone
          • Oct 2014
          • 344
          Re: C-0211 on C458
          C458. TROUBLE CODE C0211...what assembly or parts are needed for this fix
          Sent from my SM-N981U using Tapatalk
          • Synthohol
            Certified Konica Expert
            • 5853
            Re: C-0211 on C458
            Dude, this thread is 3 years old.
            By now I hope someone removed the paper from behind the tray and lived their life to the fullest.
            • antone
              • Oct 2014
              • 344
              Re: C-0211 on C458
              Lol this is not paper behind the tray......tray 2 and bypass doesn't work!
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                Re: C-0211 on C458
                BUT, you posted almost exactly THREE YEARS AGO that all you have to do is hold the door shut for your solution to this issue. Why not just do that or does that not actually work?
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • canalstr
                  • May 2021
                  • 1
