Good day guys. Please anyone incounter this before there are white spots on cyan color. I already replaced cyan iu and clean evry thing. Like itb and transfer rollers.and its only in cyan other colors are good.
Bizhub c360 white dots on cyan
Re: Bizhub c360 white dots on cyan
You mentioned having replaced IU do you mean developing unit as well as drum unit? I have experienced similar fault whereas the main cause was bad toner though the HV could also cause such a fuss.
Best of regards,
Ahmed R. Chamumi.Comment
Thanks for the reply guys. Imean i change the cyan drum with same result this machine only have 70k copies on it and 57k is black. What should i do with developer guys do i have to replace it?there is no glory without sacrificeComment
poor quality paper also causes this problem.
try good quality paper and see if the problem is resolved. If so, its not the machine.Comment
Matt
Yeah, it looks like undertoned developer to me too. I'm wondering how the TCR sensors read, especially cyan. Maybe hopper bushings?
It must be resolved by now, yes? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
