Convert Biz C353 to a c253, hypothetically...
  • copyman
    Owner / Technician
    • Sep 2005
    • 4726
    Hypothetically, if you remove the MFP w/NVRAM, printer control, HDD, RAM & postage stamp size serial # board from a C253 and put them all into a C353 wouldn't the machine become a C253? I cannot think of what else would make the machine think otherwise. By the way only different part # between the two models is the MFP board. Looks like all other parts are same, of course the IU/toners are different because of the chips.
    Probably wondering why I'm asking this. Long story, will explain later.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Convert Biz C353 to a c253, hypothetically...
    fusing exit cooling wiring harness is different between 203/253 and 353 as the 353 has 3 fans and the 203/253 only has 2.
    drive system wiring harness unique to ppm speed model. Why would they make 3 different versions of the same cable, perhaps this is one of the several secret ways the machine knows which version it is ?
    fusing relay harness different between 353 & 253/203
    • copyman
      Owner / Technician
      • Sep 2005
      • 4726
      Thanks for the info. Shoots that theory to hell!
      • bechir00011
        • 24
        sorry ,Mr ,i need minolta c253 firmware, i can buy it, thank you very much
          start your own thread ... piggy backing might not get you what you need.
