Service Notification Failed message
  • progoffice
    • Nov 2008
    • 337
    I've got a C364e that is displaying a message randomly that says "Service Notification Failed" turn machine off and back on and will be blinking orange. The machine will still copy/print/scan etc. while in this state, so it's not like a service code is present. I have the machine configured to email us meter reads and status notifications. Among these, I have the machine programmed to let us know if toner/waste toner is low and if there is a service call generated on the machine. Scan to email works, and I've forced a meter read to our meter inbox successfully. Perhaps the machine is trying to email us a status notification and can't??? There are no service codes in the history. Or, is this message related to Vcare settings? This is a refurbished machine, so I'm not sure if it was connected to a remote server for "service notifications" in the past. Any help is appreciated.
  • emujo2
    • Mar 2017
    • 1579
    Re: Service Notification Failed message
    This is a message generated when the MFP can't reach KMs Vcare server (HTTP 1 way only, SMTP is not monitored like this. If you are not using vcare just go into service mode and do a vcare date clear (not a MFP data clear). if you require vcare then something has changed that is blocking the MFP from getting an outside web connection, and it will continue to display this message until it's corrected. Emujo
    • progoffice
      • Nov 2008
      • 337
      Thanks emujo. It took me a while to find where the vCare RAM clear setting was, but I think I got it taken care of.
      • D Colour
        • Oct 2008
        • 217
        Hi
        We are having the same problem with an ex-lease machine. Turn Main Switch OFF and ON. Service Notification Failed. If you turn it off/on the message does clear for a while, but then returns.
        We have checked Service Mode/CS Remote Care and done the data initialise, also entered (albeit a made up 7 digit ID Code) and done the RAM Clear.
        Also entered CS Remote Care via the web browser and run the data initialisation in there.
        Had a look at Service Mode/Machine Update Settings, but nothing is turned on here.
        Are we missing something?
        Everything that has a beginning, has an end.....
        • KMFLT3CH
          • May 2017
          • 242
          There should be two things to clear in service mode to disable VCare communication completely:
          SVC Mode > CS Remote Care > Start Maintenance > input any 7 digits > END > Detail Settings > RAM clear > Set > END
          and
          SVC Mode > CS Remote Care > Server Settings > Data initialize > Yes > END
          • jonbonse
            • Jun 2009
            • 737
            Can you let me know where it was?
            • KMFLT3CH
              • May 2017
              • 242
              Your answer is literally right above your question
              • jonbonse
                • Jun 2009
                • 737
                Yes I saw that however could not locate the first part (RAM Clear) ....
                  NOT RAM CLEAR... that will really muck up the works.
                  • jonbonse
                    • Jun 2009
                    • 737
                    This bit:
                    • copier tech
                      • 8193
                      and
                      Thanks for the info this helped me out today!
                      However I didnt do the 2nd step but message went away?
                      โ€‹
