Data Light blinks while sending print job to Konica Minolta 360,
  • musthafavi
    • Aug 2017
    • 76
    Koinca Minota C360 Image transfer belt has been changed and after changing also warning message was show up to change image transfer belt unit, so reset the value, after that i am facing those issues
    1.While sending print to Konica, data light keeps flashing and not printing
    2. Unable to configure SMB/email scanning functions from public usermode, so configured from Admin mode (SMB scanning), but its doesn't show up in printer display
    Note:
    I can make copies
    I can print demo page
  • musthafavi
    • Aug 2017
    • 76
    Re: Data Light blinks while sending print job to Konica Minolta 360,
    Originally posted by musthafavi
    Koinca Minota C360 Image transfer belt has been changed and after changing also warning message was show up to change image transfer belt unit, so reset the value,after that i am facing those issues
    Note:
    I can make copies
    Please help me to short out this problem
    • Woxner
      • Jul 2011
      • 851
      do a new release on the belt and fuser. ck the other counters. these might need the fuse cant remember to reset the counts
      • musthafavi
        • Aug 2017
        • 76
        Thanks for your reply
        What I observe that, there is some authentication issue, authentication device was connected before and its removed now, so always popup warning message "Authentication device is note found" so I UNSET from System mode
        Pleas see the attached screen shot, getting message "A general user cannot refer to. Please ask an administrator"
        while trying to configure SMB from public use
        Please help me to restore public user's default permissions
        • REGSIS
          • May 2016
          • 435
          Turn Off authentification
          Utility-> Admin settings (password: 12345678) -> Authentification/Account track (set to off)
          User data and public user permissions will be cleared
          • musthafavi
            • Aug 2017
            • 76
            I tried the same, but still having the same problem
            • Woxner
              • Jul 2011
              • 851
              do a network clear in service mode. i have countys that do this so no one can do that. you may also have to do a data clear. but do the network first and try that
              • musthafavi
                • Aug 2017
                • 76
                Thanks for your replay
                Problem has been solved except printing issue, While sending print to Konica, data light keeps flashing and not printing
                Account tracking is OFF
                Please help me to solve this isssue
                • musthafavi
                  • Aug 2017
                  • 76
                  I did the above tip (Network Clear) and printing issue has been resolved
                  Thanks for your support and still I need your support
                  Now User Box, Store Address and direct print portions are not available in web interface and from utility also some options are missing
                  Even I has been checked the options under Network Tab, but unfortunately those settings are not available
                  Please attached screen shot for the further details
                  Please help me to enable missing options
                    • 14813
                    Go into service mode and re-install the HDD. You will also need the movie data once the HDD has been installed through service mode.
                    • musthafavi
                      • Aug 2017
                      • 76
                      Thanks for your support, Problem has been solved
