konica C7000
  • MNS
    • Aug 2025
    konica C7000
    Hello Everyone.
    Please i am using C7000 printer. Suddenly i got the error. (Error Code 3303). this Error is coming when i am sending job to print. and when i restart the printer the error will goes clear. What can cause of this error?
  • snoopyed
    • 8
    Re: konica C7000
    Originally posted by MNS
    Hello Everyone.
    從我的iPhone使用Tapatalk 發送
    • snoopyed
      • 8
      Re: konica C7000
      Hello Everyone.
        Re: konica C7000
        are you an End User? You can sometimes find a service manual on the web.. or go to the " Manual Request" forum here.
        • Woxner
          • Jul 2011
          • 852
          • methogod
            • Dec 2008
            • 921
            Re: konica C7000
            unplug cooling fan, see if it goes away. if so bad fan, pinched wires, loose harness wires - fine that harness in generals breaks from constant removal in my shops.
            • MNS
              Re: konica C7000
              Thanks everyone.
              i removed the fusing unit and clean the fan and unplug and plug the connector again after fixing back printer started printing again. thanks alote for help. can someone help with me with manual. ii need a service manual.
              thanks again
                Re: konica C7000
                Thanks everyone.
                thanks again
                you can try to google it or put in a request in the " Manual Request " forum.
