Konica Minolta Bizhub Pro 951
  • Flash
    • 378
    Does anybody know how to reset the ORU-M maintenance message? I have reset all the parts counters that are past yield, checked DIP SW 12-5, 15-0, and 2-2. Can't find anything in Utility or Admin mode.
    • 23010
    Re: Konica Minolta Bizhub Pro 951
    You reset the appropriate parts counters. Did you reset the PM counters in that same menu? Did you run any of the drum peculiarity adjustments after changing parts? =^..^=
