Anyone swapped over a RIP? Got ic-306 issues!
  • dagoof
    Still learning...
    • 220
    #16
    Re: Anyone swapped over a RIP? Got ic-306 issues!
    Thanks again for trying to help Alb - this was a fresh fdisk'd drive in the RIP though (after the original became totally unreadable) so I'm not sure that'd make any difference? I think the Fiery re-install cd fdisks anyway as part of the installation?
    I'd also tried 2 different sets of Fiery discs I have. Not easy, eh
    • Albonline
      • Sep 2008
      • 1151
      #17
      ok then try this , there should be diagnostic software that came with the rip. start unit off of it and when complete say to copy to jump drive. check text file for what is good/bad as far as hardware.
      i think the 306 looks for a certain size/type of drive before it will load. i have cloned drives from these ,however a cloned drive will refuse future reloads from the dvds.
      • dagoof
        Still learning...
        • 220
        #18
        Ok, I've tried running the diagnostics a couple of times - on the system test I get:
        [System : PCI Routing Test] SYS06 E011 * Verify 1 card(s)
        I did the 'full test' but it must've crashed on the HDD test (ran for 24hr with no progress) - but strangely when I do all the HDD tests independently (performance, surface and smart IIRC) they all pass.
        • jpablo_mza
          • Jun 2018
          • 30
          #19
          Dear, I need the version 2.0 of that fiery (Pro80), I lost the discs and xp does not start, someone will have the images ?? Thank you very much for your help
