bizhub 454e df 701 doc feed ( originals left on glass)
  • brent
    • Nov 2008
    • 1212
    at first I couldn't get it to do the same problem as customer described.. then it did.. I could not get it to work while the doc feeder is completely open
    I was able to push on the actuator in the back and each time the scanner came on.. so I feel the sensor is working any thoughts on why it
    keeps saying originals left on the glass? if I shut machine off and on. it works the first time every time. any help would be appreciated
    brent
    • 14726
    Re: bizhub 454e df 701 doc feed ( originals left on glass)
    brent
    Make sure the DF is square on the scanner bed. If the magnet on the DF doesn't line up with the reed switch under the front scanner cover it will not clear the original on glass.
    • Synthohol
      Certified Konica Expert
      • 5824
      had the same thing recently, i removed the glass and the cover around the CCD and blew it all out with an air can.
      there had to be a dirty sensor on the CCD board in my case because that fixed it.
      also a dirty platen cover will do it too. had a lot of pen marks and splatters (hows that happen?) trick it into thinking there was something on the glass.
      • mo0651
        • 1054
        Clean the glass, perform NON-Image area erase in service mode. Your problem will be solved.
