IC-601 controller stopped working
  • onecasey
    • Sep 2017
    • 4
    [Misc] IC-601 controller stopped working
    Hi,
    I am new to posting but your information has helped me on many occasions and I welcome any help that you may have. I have a Konica Bizhub Press c7000 with an IC-601 controller. Everything has been functioning perfectly until yesterday. Suddenly, the system lost connection to my network. I checked the server, the controller, the network settings, and the computer installation and all had the correct IP settings. I tried rebooting the system, but when I went back into the control panel administration settings to check them, the controller options are grayed out. They are also grayed out on the main controller settings. Any idea what is causing the issue and how to correct it?
    Onecasey
  • tulintron
    • Jul 2014
    • 668
    Re: IC-601 controller stopped working
    Originally posted by onecasey
    Hi,
    Onecasey
    Try restarting the printer in service mode. when the IC601 lights controller at the bottom of the screen,
    try formatting the HD in the ALL option. Then, make the network configuration again.
    • onecasey
      • Sep 2017
      • 4
      Thanks so much. I'll give it a try.
      • onecasey
        • Sep 2017
        • 4
        Hi,
        I have reformatted hardrives on KM 1051 with no problems. The c7000 is a bit different. When I reboot in service mode, I am not finding any path for reformatting the drive. So, I went into the adminstrator settings menu > Security > HDD management > and can only find backup and restore options for the data and not the format options. Exactly how do I re-format the HDD on the Bizhub Press c7000?
        Onecasey
        • Synthohol
          Certified Konica Expert
          • 5871
          You don't do anything for the IC601 through the copier.
          You need a laptop and a network cable and the firmware for the ic601. It gets flashed using the konica tools.
          It's been a long long time since I had to work on one but that's what I recall.
