BizHub C364 stuck with blinking light
  • gavrielx
    • Oct 2015
    • 59
    Hi ,
    I have a problem with BizHub C364 that gets a job from one of the computers , that stuck the machine with a Blue Blinking Light (Reciving Data).
    The problem is :
    1. there are fifty computers there and you can't know who sent the job to delete it from the spooler.
    2. The driver is installed locally on each computer.
    When i change the mechine IP it start to work again.
    I'd be happy to receive any suggestions for resolving the issue
    tanks,
  • lilleputte
    • Jan 2013
    • 153
    Re: BizHub C364 stuck with blinking light
    Speak with the it department on the company
    Maybe some kind of network reset will resolve this issue ?
    • Max
      • Oct 2011
      • 561
      Fifty computers and no print server is quite poor from IT point of view. Tell them straigtthat you cant be expected to check every Pc for problems/driver updates. There must be a Pc that never gets turned off that can be used as a print server. Failing that a second hand laptop hidden under the table would do the trick just as well.
      • gavrielx
        • Oct 2015
        • 59
        Unfortunately, this is the form of work that exists there
        Maybe I'll ask them to shut off all the computers in the organization after work hours
        And turn off the network switches.
        • guitar9199
          • Sep 2016
          • 1100
          "When I change the machine's IP it starts to work again"...??
          Sounds like an IP conflict to me. With smartphones, tablets and computers all trying to get on a network, and only 252 (usually) available IP addresses, you need to make sure you either use MAC Address filtering on the IP addresses, or grab a static IP that's out of DHCP range to avoid this.
          • copier tech
            • 8172
            Do you mean you changed the ip address to stop the corrupt print job?
            I would start by updating the fw & enabling function version 7 if not already set.
            • mo0651
              • 1054
              I would disconnect network cable. Power OFF/ON machine. Let it come to ready. Make copies. If light is still out, then plug in cable. Network is causing issue. Now it is IT dept. problem.
              • Hansoon
                • Sep 2007
                • 3389
                A noob like me would love to know why. Or to put it otherwise: What is the advantage of a Printserver and when should I have one?
                Hans
                • gavrielx
                  • Oct 2015
                  • 59
                  when i change the ip the computer can't find the printer and then everything work again.
                  but if i have to change the ip i have to change it on 50 computer also because they dont have printer server.
                  • Max
                    • Oct 2011
                    • 561
                    Hans
                    When you install the driver on a server and share it across 50 Pc's you have controll over it. In this case a job in a queue will be shown on the server and can be easily deleted/reset. If you have 50 PC's with 50 individual drivers and every one is messing with it, makes troubleshooting difficult. "Printserver" a second hand laptop with shared printer driver under the table will do just fine.
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      In order to find who is the culptit try this. Turn off the bizhub. Find another printer nearby, a small hp for example. Assign that printer the bizhub IP address. The job will print there and use that to find which user needs a newer driver. Change all the ip addresses back.
                      I had to do this because nobody could find the job to cancel it and 'our' equipment had the error so was our issue.
                      • gavrielx
                        • Oct 2015
                        • 59
                        Your advice works and solve the problem.
                        tanks.
