BizHub C6501 - Using a Mouse Instead of Touch Screen
  • CPM Mike
    • Nov 2015
    • 32
    I had read other posts in this forum that suggest I can use a USB mouse when my touch screen dies.
    Can anyone advise how to get this to work? I have plugged a USB mouse into the Fiery Controller but never see the pointer on the screen.
    If you could provide a step by step process, I would be very grateful.
  • dagoof
    Still learning...
    • 220
    Re: BizHub C6501 - Using a Mouse Instead of Touch Screen
    Hi Mike,
    I believe there's a panel you remove on the back of the 'arm' that the screen is mounted on (the pivoting cylindrical section) - at least I think it's around there!
    • Synthohol
      Certified Konica Expert
      • 5849
      here it is.
      • CPM Mike
        • Nov 2015
        • 32
        I am very grateful that you posted the photo! I would never have thought to look under the little plastic cover as I always thought the mouse plugged into the Fiery Controller.
        Thank you so much!
