Konica Biz Hub 600 cleraner drive clutch question
  • tonerjockey
    • Apr 2014
    • 567
    Hi Guys. this unit had a toner back up. i found the cleaner clutch on the inboard end of the toner recovery roller shaft was rusty. i disassembled and tried to clean and it still was not turning when i made a copy. i ordered a new clutch. when i returned to replace it, the old one was scorching to the touch. i replaced the clutch, and when i made some copies, the toner recovery auger tube gears were still not turning.
    are the out board waste toner transport tube gears connected to another drive? arent those supposed to turn all the time when making a copy??
    any help would be appreciated. have a very nice day, Jim
    Re: Konica Biz Hub 600 cleraner drive clutch question
    IF the clutch was that hot to the touch.. it could have fried the circuit of the board that controls it... although I would assume that would kick an error code
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      If you are sure "you can turn the cl unit augers by hand" with no binding. You can try changing softswitch. I seem to recall there was a bulletin about setting the clutch to run all the time. This was suppose to prevent paper dust build up and stop developer from crashing, which didn't help of course. Worth a try to change the SS to turn clutch all the time.
      Anytime you recycle toner on a high volume machine you are looking for trouble. This was "Konica's" poor design that they brought with them when they merged with Minolta. They stuck with this design for 10+ yrs! It is in my top 10 for worst machines! "sorry had to vent"
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        Attached is the bulletin about the cleaning unit clutch and also another about a gear.
        • HuronMan
          • Jul 2009
          • 68
          I've been unplugging these so they are always driving the auger. If it still doesn't drive, there is a 1way in the drive unit on the shaft that drives it. Remove the carriage, reach in and grab the gear sticking out and see if it slips.
          • Mr. Joshua
            • Nov 2011
            • 31
            +1 for this ^
            I humbly claim to be able to finesse these machines into running very well and this is top of the list in my bag o tricks
            • tonerjockey
              • Apr 2014
              • 567
              Hi guys. Thank you Phil, Copyman, Huronman and Techitiion. this is so helpful. i will go back today and see whats the WTF? i really appreciate your help (again). Happy Friday to you guys. have a great weekend, Jim
              • tonerjockey
                • Apr 2014
                • 567
                Thank you very much to Copyman and Phill. i was able to set the dip soft switches. i think the last one did it. now when i cheat the interlock with the drum cover off, it starts the toner recovery drive before a copy is made. prior, it didn't turn when i made 10 copies. and i suspect that since the cleaner clutch must energize to stop the drive, that is why it was hot. the inner one way gear was fine. this machine as well as his C353 in a major name ship and send shop, has very low copy counts, but everything is falling apart like a 1968 mustang. so i told him i suspect at some point, the counters were zeroed, and has no bearing on actual wear and tear. the biz hub shows 334K and everything way long in the tooth. i have another customer with over 836k and that one you could eat off of.
                which brings my next post query for the other one.
                thank you guys SO much for the assistance. Jim
                • allan
                  RTFM!!
                  • 5462
                  I always unplug the clutch on the cleaning unit. It tend to not work well with low volume applications and fills up the unit with toner.
                  Why bother with dip switches just disconnect it. If all is well on the machine it makes no difference...
                  Whatever
                  • tonerjockey
                    • Apr 2014
                    • 567
                    thank you Allan, that is actually a good idea. i will try that in the future. i have another one that over time drops toner. i bet it is the soft switch settings that are reducing the recovery drive.
                    i hope you have a nice day, Jim
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4718
                      Hey tonerjockey, glad it worked out for you. Actually that machine dropping toner is just the nature of "that" beast. Even with cleaning clutch running all the time it will still drop toner. As i have said before the main reason is developer gets contaminated from paper dust. Recycling toner is just a BAD design! Lucky to get 100k out of a developer. If possible you could have the cleaning unit clutch running even in sleep mode or machine turned off and it would still drop toner
                      One of the reasons I don't use my vacuum anymore is because I don't have any more of these toner pigs.
                      • tonerjockey
                        • Apr 2014
                        • 567
                        yea, i hardly ever use mine anymore. after i invested in an Atrix, and scuttled my noisy 3M.
                        • allan
                          RTFM!!
                          • 5462
                          Like copyman said, change the developer every 100K. That and keeping an eye on the web roller is the trick on these.
                          Whatever
                          • tonerjockey
                            • Apr 2014
                            • 567
                            ok, great info. but Photoconductor stays on the normal cycle? i think off hand it was 250k, and the dev was 500k. but i will check.
