Just fired up an old di520 gave "misfeed detected at o" (o being little dot), Opened indicated area (fuser drawer), cleaned out a bunch of garbage from in their and tried a test print. Paper made it all the way to the fuser and jammed there. Cleared jam, now it wont clear the error misfeed detected at o" (o being little dot on fuser) Tried to clean out again but to no avail... Any suggestions?
di520 Jams in fuser
What location does the jam show in the jam counter? There is a sensor in the upper left door that can fail. Also, the exit guide can get hairline cracks in the fingers causing jams.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed. -
If the misfeed dot will not go away, then there is either something blocking the photocell in that location, or you have a bad photocell. Go into tech rep mode, to the I/O check, and you can use that screen to check your photocells. Just find the photocell in question and actuate it while watching the I/O check and you can see it switching on and off.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
The way to reset a misfeed or error code is to open and close the large front panel after the paper has been cleared. This switch is to reset fuser and exposure lamp codes, not misfeeds and regular error codes (and is not for end users).the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Sounds like it's time to call a technician.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
