cyan color fails to print on ineo + 454e
  • jakani
    • Dec 2014
    • 147
    hello everyone ,
    here i will attach a demo page from two different printers and you can see the difference in colors ! num�risation.pdfnum�risation0001.pdf
    there is no cyan color !
    i never had this problem before and i don't know how to solve it
    any suggestion would be much appreciated
    thank you very much
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: cyan color fails to print on ineo + 454e
    A broken last gear on the cian dev unit can cause that. The printer does not error
    while it isn't producing blue at all.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • 23008
      What have you done so far? =^..^=
      • jakani
        • Dec 2014
        • 147
        thanks for your suggestion , no there is no error message or anything ! it prints normally without cyan color
        thank you for replying
        i did nothing but i'm willing to change the dev unit
        • jakani
          • Dec 2014
          • 147
          hello everyone ,
          i found out that the cyan dev unit was not turning right when i rmeved it i found tonner stuck in front tube and a mix of developer and toner inside the printer , i replaced it and the printer worked just fine but i have to go back to clean that inside very well
          thanks everyone
