C 6501 0101 error
  • selmila
    • Aug 2012
    • 133
    C 6501 0101 error
    Hi all.
    I am unable to recover 0101 error code in the machine, the machine condition is when I give a print the engine starts it gives a dragging noise while picking up the paper. Any suggestions.
  • laitang
    • Nov 2012
    • 627
    Re: C 6501 0101 error
    Check Paper feed motor (M41)
      Originally posted by selmila
      Hi all.
      what have you done to the machine? I'd have you check for paper not near a sensor? Cleaned the printer along with feed roller?
      more info needed.
      • selmila
        • Aug 2012
        • 133
        I have replaced the motor and drive assembly but still did not recover the problem.
        • selmila
          • Aug 2012
          • 133
          more info needed.
          Hi phil.
          The error occurred by it self and i have also checked the feed roller.it looks good. I have replaced drive moter and the assembly.
            Hi phil.
            if it comes from on power on you could have a sensor stuck.. make sure all sensor are clean and move freely
            • selmila
              • Aug 2012
              • 133
              It is clear path and sensor..the machine sounds like it is dragging like over loaded and slows down while pulling the paper from the bypass / tray
              • venluckey
                • 36
                Quoted from this thread:
                C-6501 (c-0101)
                "1. When the sub power switch (SW2) is ON, no response is received from the Printer Control Board (PRCB) within the specified time because ICP23 on PRCB is OPEN.
                Check for any pinched, shorted or cut wires. Check installation of transfer units. Replace the failed DRPS and PRCB.
                Note: If unable to locate ICP23, it can be found in the lower left section of the PRCB near connector CN301.
                2. Transfer drive motor M18 has failed, connector was not seated properly, or connector and/or wiring from PRCB to motor has been damaged.
                Check connections and wiring from PRCB to M18. Replace the PRCB and also M18 if necessary."
                By
                Nelo
                Its an older post, don't know if that helps.
                • selmila
                  • Aug 2012
                  • 133
                  C-6501 (c-0101)
                  By
                  Nelo
                  Thanks venluckey.
                  I'll check on .
                  • tulintron
                    • Jul 2014
                    • 668
                    Hi all.
                    Apologies to everyone for resurrecting a topic, but I'm having the same problem on a C7000.
                    J-9401, CO101. Motor dragging when loading paper or turning paper in duplex.
                    At times, it works normally. In others, it presents the problem.
                    changed parts
                    PRCB, Paper Feed Motor (M41), ADU Clutches, Duplex.
                    Firmware Updates. V40.
                    Please, any help is welcome. Thank you
