Is control panel bord to change?
  • ctucci
    • Oct 2017
    • 7
    Hello,
    I have a C252 BIZHUB problem.
    The machine startup, the control panel come up displaying menu and so on.
    The copier is connected on the network.
    But it do not take in account any command from network pc and, if I remember well, touch command do not responds.
    Did you think that changing control panel board, system can be again alive?
    Is there a process to diagnostic system and see witch part have a fail?
    Thanks a lot
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Re: Is control panel bord to change?
    Did you do the basic things, like let the machine automatically pull an IP address then ping it? I would start there first.
    • ctucci
      • Oct 2017
      • 7
      Thanks copyman,
      I will do the test and inform you but I need time. This copier is physically far from me.
      Bye
      • copyman
        Owner / Technician
        • Sep 2005
        • 4700
        Also, that model has known issues with touch panel not responding. You have to replace just the touch glass. Sold on internet for around $50 USD.
