I have a BZ223 on which the main drive motor constantly runs after doing a copy or print.
On switching on the machine it warms up as normal and appears ok but as soon as a copy is done, after the sheet exits, the main motor will continue to run turning the fuser/drum etc.
There are no jam or error codes reported.
Parts changed so far are the PRCB and drive motors.
I've picked up this call from another engineer who replaced the bypass tray assembly which the customer had damaged. He isnt sure if the motor was constantly running after he left it.
Has anyone experienced anything like this?
