bizhub 654e drum rest
  • maj143
    • 55
    hi all
    please i have bizhub 654e i want to rest the drum unit can any tech help me with that
    thanks alot
    • 14972
    Re: bizhub 654e drum rest
    Originally posted by maj143
    hi all
    thanks alot
    What do you mean when you say you want to "rest" the drum?
    • maj143
      • 55
      Hi
      I mean i want to clear the drum unit error without change the drum unit
      I think there is way to do that any help
      • habik
        • 2013
        You want to reset the life or image quality problem
        Sent from my Mi A1 using Tapatalk
        Firmwares HERE
        • maj143
          • 55
          Yes i want to reset the life
          The copier not working show change the drum unit
          • insigniawales
            • 29
            It is not possible to reset the IU life through the machine. The consumable resets the counter.
            Sent from my SM-G903F using Tapatalk
            • Woxner
              • Jul 2011
              • 853
              the drum warning can be turned off in service mode to never stop
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                from memory the "chip" on the drum is 3 pins, between 2 are a resistor (type identification & installed detection) and between other 2 pins is a very light duty fuse, blown when counter is reset and new to be detected as new. They are smd and very small and fidly to replace.
                I have jury rigged a pico fuse between the appropriate pins as required in an emergency to get a blown new toner cart level reset etc.
