C458 tripping
  • habik
    • 2013
    #16
    Re: C458 tripping
    Originally posted by mike4001
    i have not done a firmware update beacuse it reboots when you boot it up to reset trouble codes so there is a very high chance it will reboot when trying to do firmware, and i have know idear what firmware version it is on i think this will probally cause more problems than solve them.
    unless you think other wise?
    You are joking right?
    Use the latest firmware you have available. If board is a pancake then sticking extra jam wouldn't hurt I think.
    Currently the latest jam is G00-R9 Function Version 4.1
    Usually update takes max 10 min. If it doesn't boot to firmware screen or keeps re-booting whilst in firmware update process in 25 min then you have board issue.
    If you have ADF disconnected then it wont see it and update only what the board can see.
    Reseating eMMC and Memory and HDD may help as well.
    Also maybe handy to check all ICP's.
    Firmwares HERE
    • Tech Helpdesk
      • Jul 2015
      • 112
      #17
      Re: C458 tripping
      From what I have scanned on the posts -- You still haven't replaced the memory !!
      We have had so many issues with the memory preventing the machines booting up, you also need to the firmware after that it would look like the MFP board.
      • Albonline
        • Sep 2008
        • 1151
        #18
        Re: C458 tripping
        disconnect the ribbon between the mc and mfp, if it still resets its the power supply or the mc board
