Need some Help...
  • methogod
    • Dec 2008
    • 917
    Need some Help...
    Need some Help... KONICA C6501 (sorry BC)
    Replaced all consumables recently...
    PM, Drums, DV, Corona Units.....
    DV units are all within spec.
    Laser Units have been replaced and have less than 2m on them.
    ***LINE IS IN MAIN SCAN DIRECTION (even though the photo is rotated)
    Line/Void does not repeat seems almost random to me...
    Swapped drums, stays with CYAN
    Replaced CYAN DV unit and DV, stays with CYAN
    Suggestions?
    Winning solution get BEER/WINE/EIGHTH of WEED on me
    • 22999
    Re: Need some Help...
    Did you say what manufacturer/model this is on? Can we safely assume that it's some kind of color copier? =^..^=
    • methogod
      • Dec 2008
      • 917
      Geeze must be one of those days...
      Thats like ordering a big mac at wendys....worse KFC.
      KONICA C6501
        • 22999
        Could it be a drive blur? Have you looked at registration rollers, registration roller drive, transfer belt drive? Confirming that you said Main Scan = Crossfeed? Is the media excessively heavy?
        • methogod
          • Dec 2008
          • 917
          The picture is heavy stock, but within spec...
          This photo is just a test print on 60# accent digital
          C & M at 120 percent...
            • 22999
            Clearly cyan ... maybe drum ground or drum drive?
            • methogod
              • Dec 2008
              • 917
              swapped drums and it stays with cyan...
              ill look at the grounding, what is the deal with the drive units...
              do they fail? I have a pulled one that is good, with almost 6m on these should i replace all 4?
              • methogod
                • Dec 2008
                • 917
                Black Cat... get this
                with some help of a real tech, he/we found the DEVELOPING COUPLING ( that drives the DV is severely worn) so in the OLD DV unit works OK, but will start skipping, in a NEW DV unit makes almost no contact...
                never seen that before.
                Can you order them as an assembly?
                  • 22999
                  Firstly, congratulations on your find.
                  No I haven't seen this before. Just make sure that the drive coupler in the rear frame is also in good condition, or it may prematurely start skipping again. =^..^=
                  • methogod
                    • Dec 2008
                    • 917
                    can you identify that part? ill replace...
                    going to do the 4 drum motors assemblies
                    and the gears...
