Bizhub 421
  • Serviceusam
    • Nov 2017
    • 11
    Bizhub 421
    The machine displays the code: C-d203. Any ideas?
  • Albonline
    • Sep 2008
    • 1151
    Re: Bizhub 421
    Communication abnormality
    between the main body control
    board and the printer control
    • Serviceusam
      • Nov 2017
      • 11
      Re: Bizhub 421
      what is the solution for this problem?
      • Albonline
        • Sep 2008
        • 1151
        Re: Bizhub 421
        this is an internal communication problem on the system board, you could try reseating the ram.unless you know exactly what you are doing on this old thing swapping out boards can be a nightmare. this problem can be from ram, nvram, or the control board. very slim chance its the cf card.
        this is an obsolete box though, i wouldn't put too much into it.
        • Serviceusam
          • Nov 2017
          • 11
          Re: Bizhub 421
          I tried with another ram and it din't work. i have another functional 421 and i'll try to swap the boards and see what's what. thank you for your help, much apreciated!
          • Zesti
            • Jun 2009
            • 308
            Re: Bizhub 421
            Description
            C-D203 at power ON and the code may not reset.
            Solution
            PROBABLE CAUSES:
            1. The OACB (Overall Control Board) has failed.
            Before replacing the OACB, reseat the NVRAM and Memory on board connections. If the issue is still unresolved, replace the OACB (p/n A0R5 H010 06).
            2. A poor connection between the scanner drive motor and PWB-SDB.
            Reseat CN62 on PWB-SDB. If the problem persists, replace PWB-SDB (p/n 50GA -905 0).
