C308 address book import to C368
  • copier tech
    • 8132
    • 14520
    Re: C308 address book import to C368
    You need to download Pagescope Data Administrator if you want to import data between different models. Regular Pagescope will only work if the machines are the same model, eg. between a C308 and another C308.
    • suomi
      • Oct 2008
      • 152
      External memory backup usb memory
      • KMFLT3CH
        • May 2017
        • 226
        You can Export and then Import address book data (and more) across different models, you don't need to use PS Data Admin.
        Enter service mode and navigate to System 2, Software Switch Settings, Switch number 72, HEX number 04, hit Fix then exit service mode.
        Enter admin mode, scroll over to page 2 and select External Memory Backup. Insert a USB drive then select Export.
        You can export an old MFP's address book, authentication settings, user settings, network settings and more onto your USB drive, then just plug it into the new MFP and Import the settings via the same steps above. This works across many different models, but not all of them.
        • copier tech
          • 8132
          Perfect, cheers for the info useful to know!
