Bizhub c253 SMB problem
  • Albonline
    • Sep 2008
    • 1151
    #16
    Re: Bizhub c253 SMB problem
    Originally posted by B0265
    Is SMBv1 disabled on the server?
    What he said!
    • habik
      • 2013
      #17
      Originally posted by TomaszW
      Hi,
      we have 6 bizhubs in our company, and now only 2 can can to SMB. All of them have the same destination list. Our file server is on Windows server 2012r2. Credentials are ok- they work in 2 bizhubs and I can map drive with them on Windows. I can scan from machines with problems to PC with windows 7. On one machine it shows Server connection error, on second wrong user name.
      What I noticed on theses machines is that when you use lowercase for hostname it wouldn't work. Also if you amending any particulars on the address book you have to always enter the password. Sync with Data admin seems to took care of the issue as you copied the good stuff over the bad stuff.
      / & \ are common mistakes as well as space behind a hostname or UID when copied from other address book.
      Good job you found a way around.
      Sent from my Mi A1 using Tapatalk
      Firmwares HERE
