konica minolta C350 error C-3C30
  • bsglobal
    • Sep 2016
    • 7
    I know it may seems strange that we still use this model of konica minolta.but I should tell u if u already don`t know that In third world we unfortunately still use this machine or even older.
    I think many of u even don`t remember the operation procedure and technicals about minolta C-350 but I hope maybe some of u could help because I`m really desperate.
    This machine was working perfectly and for some reasons I had to change the NVRAM which I dont Have access to the old one anymore.
    Since I changed NVRAM with the same type of minolta C-350 the following happend:
    1-At first the first print or copy jammed even before the paper pick-up
    2-This machine`s setting at service mode- "marketting area" was set to Europe before and then I changed that to US and it worked.but does not produce test print in service mode and also has some other problems with size.
    3-then suddenly there was this Code "C-3c30" came up for the first copy every time.
    Actions taken:Changed the control board and MFP control board with the machine that the current NVRAM belonged to -entered serial number but did NOT work.
    Strange thing that I have 2 minolta C-350 with exactly the same problem.
    Any help will be really appreciated.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5820
    Re: konica minolta C350 error C-3C30
    didnt see that code in the manual or on SSD.
    double check the serial #s in service mode, may not be correct.
    have you tried BASE firmware?
    the NVRAM cannot be swapped from another machine. has to be new to marry itself to the copier (unless you want to swap a few more boards along with it maybe.)
    good luck.
    • Zesti
      • Jun 2009
      • 308
      Description
      What does the C3C30 code indicate?
      Solution
      The C-3C30 code indicates that the correct date and time must be input into the copier. To access the date/time mode, press the following keys in order: Stop 1144 Clear in service mode and then in administrator mode.
      • bsglobal
        • Sep 2016
        • 7
        good luck.
        Checked the serial and its allright
        the original NVRAM is not available
        I dont know how to BASE firmware...But I think it needs some sort of very old memory card which I could NOT find.Is there any easy way to update the "firmware"???
        • bsglobal
          • Sep 2016
          • 7
          Originally posted by Zesti
          Description
          Solution
          Thanks buddy.I did that and didn`t work.
          Any more help please....
          • Synthohol
            • Mar 2016
            • 5820
            dod you change the date and time in BOTH places?
            Error
            C3C30
            Root Cause
            PLEASE CALL TECH. SERVICE. CODE: C3C30 at power up.
            Workaround/Fix
            CAUSE: The incorrect date and time has been programmed or does not match between the 2 setting locations.
            SOLUTION: To input the correct date and time, perform the following:
            1. With the machine displaying the failure code, press STOP, 1, 1, 4, 4, C (clear).
            2. Enter eight 0s (00000000) and press enter.
            3. The Date/Time input mode will now be displayed.
            4. Enter the Year, Month, Date, Hour and Minute in that order using the 10 key pad.
            5. Press ENTRY.
            6. Press END.
            7. Enter Admin Mode.
            8. Select Admin Set and screen 3 of 4.
            9. Enter the same date and time that was programmed in the other location and enter.
            10. Open and close the front door to reset the failure code.
            Note: When entering the month, day, hour or minute; enter a 0 first if the data is a single digit.
            • bsglobal
              • Sep 2016
              • 7
              Error
              C3C30
              Root Cause
              Workaround/Fix
              5. Press ENTRY.
              6. Press END.
              IT WORKEEEEEEED. I just don`t know how to thank u.
              After months without a solution !!! U finally helped meeeeeee.some of the friends here mentioned the procedure but ur instructions was perfect and clear.
              I almost got rid of the these konika minolta c350s because I thought They`re never gonna be fixed.
              Now I`m gonna make a lot of money with these konika minolta c350s.
              • Synthohol
                • Mar 2016
                • 5820
                ...service mode and then in administrator mode.
                he said it first! i just posted more details.
                glad you got it sorted.
