IC 415 controller button on 1060 is off but it works
  • liakouras
    • Feb 2011
    • 13
    I have a strange problem with a konica 1060 with ic 415 controller. After a system software installation ver 2.1(i was have a fiery no boot problem), after the installation was copleted i saw the masege ready to receive, commant workstation connect properly and we send printings without problem. But the controller button is gray. Before this problem everything was well. Its not first time i load system softaware after a problem and many times i changed the hard disk without any problem at the end. The machine firmware is 25 controller firmware is 25 and browser firmware also 25. Everything is up to date. Any ideas?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: IC 415 controller button on 1060 is off but it works
    SOULTION: Format the three mainbody HDD's using option 16 in Service Mode.
    • Profat
      • Mar 2019
      • 3
      Please i need the system software ver 2, i want to upgrade mine
      • Synthohol
        • 5892
        just asking, why upgrade if everything works?
        • Profat
          • Mar 2019
          • 3
          Mine always go off, presently its showing controller unconnected, and controller icon gray. try reloading but to no avail
          • Christian_W
            Support Specialist
            • Jan 2011
            • 33
            If you work with a 1060​L I think you need a special patch for the IC-415 to connect it to the Printsystem.
