Bizhub c280. Possible to print A3+ from bypass tray ?
  • lilleputte
    • Jan 2013
    • 153
    [Misc] Bizhub c280. Possible to print A3+ from bypass tray ?
    Hi.
    Is it possible to print A3+ from the bypass tray ?
    According to the specification, it should work but not in reality
    The A3+ is not fitting into the bypass tray
    /lilleputte
  • copyman
    Owner / Technician
    • Sep 2005
    • 4697
    Re: Bizhub c280. Possible to print A3+ from bypass tray ?
    You are right specs say bypass tray can feed up to 12x18. A3 paper is 11.7 x 16.5 so it should work. Are you having trouble with the width 11.7 or the length 16.5 not fitting?
    I know this is a stupid question but are you opening the additional small tray on the big bypass tray. Sensors are on this small door for larger paper and needs to be open for machine to recognize the larger paper. Also A3 size paper would hang over the end of tray if you don't open.
    • AjitN
      • Mar 2009
      • 287
      Hi
      What is the exact size of A3+
      I think it is 12.992 inches by 19.016 inches ( which is also called A3 extension, if I am correct)
      I do not think C280 can handle this width.
      Please let me know if there is any turnaround solution.
      Regards
      • allan
        RTFM!!
        • 5462
        Used made up paper
        Had a customer than printed and trimmed down to an A3 with some help.
        Whatever
