FS 534 finisher jamming
  • Scarekrow
    • Feb 2012
    • 81
    [Jamming] FS 534 finisher jamming
    Has anyone had this problem on an FS 534 finisher
    IMG_0814.MOV - Google Drive
    • 23008
    Re: FS 534 finisher jamming
    Something like this maybe?
    http://www.copytechnet.com/forums/ko...gulating+plate
    • Scarekrow
      • Feb 2012
      • 81
      Yes I read that, but on the video it clearly show the arm moving in at the wrong time, as if it thinks it has reached it's count to push out the batch but hasn't noticed there is an extra sheet coming in, is that related to paper cuts?
      • Dcopierdoc
        Check the paddle rollers at the exit
          • 23008
          I think that I would take a look. =^..^=
          • Scarekrow
            • Feb 2012
            • 81
            Ive been out to it, it is letting through the next piece of paper it should be holding back while it ejects, or so it seems, I will have to look at the theory of operation,
            • CraigW
              • Dec 2010
              • 417
              What are the jam codes when this occurs ?
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Abso-friggen-lutely papercuts in the alignment paddle. Change these bastards at least once a week these days. Classic symptom.
                The updated version with even more metal just cuts elsewhere now so still not solved but will be good for a while with new ones.
