Bizhub c652 TCR level Black to High C-2558
  • selmila
    • Aug 2012
    • 133
    hi.
    C 652 black print is poor, the TCR level is 14.20 which means high toner density detection in developer but there is no toner in the developer! i have changer the developer but the machine get stuck at C 2558!
  • habik
    • 2013
    Re: Bizhub c652 TCR level Black to High C-2558
    Originally posted by selmila
    hi.
    I presume there is toner in bottle and hopper and it is supplied to the Dev.
    If it is then:
    Print 20x A3 K halftone at full 255 gradient and then "teach" the TCR sensor in Dev unit that it has incorrect TCR level due to being in New environment. To do it select Manual toner add in service mode.
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
    • Zesti
      • Jun 2009
      • 308
      Have you changed only developer on developer unit?
      If there is bad or no TCR sensor connection it give high TCR value.
      Check your TCR sensor connection.
      • selmila
        • Aug 2012
        • 133
        If it is then:
        hi.
        yes the toner bottle and the hopper is good.
        i cant print any test patters due to machine stuckon C 2558.
        • selmila
          • Aug 2012
          • 133
          hi zest.
          The TCR sensor connection is good.
          • copier tech
            • 8192
            This is an important question "Have you changed only developer or developer unit?"
            • selmila
              • Aug 2012
              • 133
              only the Developer is changed
              • Zesti
                • Jun 2009
                • 308
                Which developer you put in, also what kind of toner you are using, generic or original. I have a bad feeling about your toner and developer.
                • copier tech
                  • 8192
                  So that is not an OEM part.
                  Fit a genuine KM dev unit that will resolve your issue.
                  • selmila
                    • Aug 2012
                    • 133
                    unit and toner is original and 40% life done
                    • Zesti
                      • Jun 2009
                      • 308
                      Where did u get developer?
                      Sent from my RHYTHM RX60 using Tapatalk
                      • Zesti
                        • Jun 2009
                        • 308
                        Ur dv tank is short on developer qty and it is over toned.
