Error code C-225B
  • masmy
    • Nov 2017
    • 5
    [Error Code] Error code C-225B
  • Techlife
    • Mar 2015
    • 27
    Re: Error code C-225B
    What model? What have you tried so far?
    • masmy
      • Nov 2017
      • 5
      I have changed the dc power unit with a old one (may be having the same problem)
      I have changed the PWCB but also with a old one
      The same with the circuit board near the PWCB on the left side
      It's very difficult to find the wrong part when new onces are not on hand.
      Thanks for your reply.
      • masmy
        • Nov 2017
        • 5
        Originally posted by masmy
        Same case with the black PC motor.
        • masmy
          • Nov 2017
          • 5
          At this Time I'm out of idea except to find a new DCPU and try it again.
          • masmy
            • Nov 2017
            • 5
            Sorry it's a Konica Minolta bizhub C 550.
            Thank you.
            • Zesti
              • Jun 2009
              • 308
              Masmy, the DCPU IS VERY MUCH culprit. I had no. of experiences of bad DCPU giving 255B error.
              • Albonline
                • Sep 2008
                • 1144
                Thank you.
                try the scanner driver board, if it works with the scanner disabled.
