Bizhub C360 NVRAM Reset
  • ATSCopier
    • May 2012
    • 11
    I have a bizhub C360 that was previously at a military base. In Page scope under General Settings, User Authentication is set to "ON (External Server)" and cannot be changed. I've tried page scope manager but I still haven't been able to change it. I also tried formatting the hard drive. I want to try NVRAM reset to see if that will help. The file that I'm looking for is A0ED0Y0-F000-GQ7-D1(00).exe I have access to mykonicaminolta.com because we were previously authorized through a NEC certification. However, I can't find that file in the C360 firmware section. Does any one know the place on mykonicaminolta that I can find it or have the file?
  • Synthohol
    Certified Konica Expert
    • 5836
    Re: Bizhub C360 NVRAM Reset
    one stop product support its in special firmware for the c360.
    search filter GQ7-D1
    • Zesti
      • Jun 2009
      • 308
      Have you tried to disable it in service mode?
      Service mode-Billing Setting-Mang. Function choice.
      • kmcopytech
        • Dec 2007
        • 141
        NVRAM Reset tool for NVRAM (Jig firmware)
        • ATSCopier
          • May 2012
          • 11
          I found it, thanks for pointing me in the right direction
          • ATSCopier
            • May 2012
            • 11
            Apparently what ever they installed disabled this choice. NVRAM reset enabled it again. Thanks for reaching out.
            • ATSCopier
              • May 2012
              • 11
              I'm not sure what options they had installed but I was able to resolve the problem with the NVRAM reset. Thanks for all of the input
