Bizhub 552
  • antone
    • Oct 2014
    • 344
    Bizhub 552
    Jams tray 2 only J2002 feeds 4 inches stops any 411 out there!
    Sent from my SM-N920V using Tapatalk
  • Flash
    • 378
    Re: Bizhub 552
    Try the paper feed clutch.
    • antone
      • Oct 2014
      • 344
      Re: Bizhub 552
      Will do
      • Woxner
        • Jul 2011
        • 852
        Re: Bizhub 552
        have you changeed the feed rollers and oneway clutches
        • antone
          • Oct 2014
          • 344
          Re: Bizhub 552
          Yes all new,even vertical gear....what motor only runs tray 2
          • tech51
            • 846
            Re: Bizhub 552
            Been a while since I've worked on one of these but I seem to remember that the locking lever on the lower right hand door could break causing a lack of pressure on the conveyance rollers. Might be worth checking that the catches and hinges are all in place....
            • allan
              RTFM!!
              • 5462
              Re: Bizhub 552
              Jip i will second the door hook being the problem.
              Whatever
