bizhub C224 has C2152 error code
  • Synthohol
    replied
    nobody checks dates anymore
    thread is over 2 years old.
  • copytech,mike
    replied
    Originally posted by mjunkaged
    IF you check it with a ohm/continuity meter and it reads closed, you have a solder bridge and really really should REPLACE the ICP so you don't blow the entire board next time it's overloaded with a stuck clutch or whatnot! A solder fuse is not a fuse, after all.
    Your wasting your time with that Ohm meter. Replace the transfer belt. You must also go into service mode and clear the belt counter by hitting "new release" when the front door is open. Good luck.
  • mjunkaged
    replied
    Originally posted by Laserbeam
    Re: bizhub C224 has C2152 error code
    That's a good Idea!
    I used a special smd-soldering iron with a very thin tip and used strong magnifying glasses.
    I will again check the solder point closely.
  • copytech,mike
    replied
    Could you have accidentally bridged the ICP with solder while soldering? Those components are so small that a bead of solder can easily bridge the contacts. =^..^=
    Its a bad transfer belt unit. End of story.
  • copytech,mike
    replied
    @ Synthohol,
    I thougt, a ICP is the same as a normal fuse? e.g. 50V/2A
    Could I bridge ICP3 with a small wire to test if the error C-2152 disappeares and than solder a correct ICP with the correct values?
    Its a bad transfer belt unit. End of story. Ive seen a spring holder broken and spring pops lose. Theres about 5 springs on each side of the belt unit.
  • Laserbeam
    replied
    Yesterday I checked the ICP for a solder-bridge. There was absolutely nothing to see.
    So, the only cause left, is the possibility that a connector had a contact resistance.
  • Laserbeam
    replied
    That's a good Idea!
    replied
  • Laserbeam
    replied
    I removed the board and for a test I bridged ICP3 with a wire. After replacement the code 2152 has disappeared and the machine works fine
    Now, I removed the wire bridge and thougt, the code would have to displayed again. Surprisingly, that was not the case
    The machine works normaly, without any error code.
    I can only imaging, that a connector on the board had a contact resistance and this was eliminated by removing and replacement the board.
    Or is there any other explanation for that?
  • Laserbeam
    replied
    here a picuture from ICP3
  • Laserbeam
    replied
    @ Synthohol,
  • K-3
    replied
    had something similar on a c454 and it was in the fuser drive section with the clutch cl5 that drives the transfer belt, you will have to take the assembly out and inspect for worn items. it is a pain to take out.
  • Synthohol
    replied
    none. you check for continuity. its a fuse. ohms not voltage.
  • Laserbeam
    replied
    yes, I have read the whole post but unfortunately I forgot to ask for the value of the ICP3.
    How many amperes or milliamperes must have a new ICP?
  • JR2ALTA
    replied
    Hello at all,
    yesterday I had the same code. Replacing with a new belt didn't succeed, after cleaning PS39 the malfunction still appeared!
    Did you read the post? People pointed at ICP3 and/or controller board
