Bizhub PRO 951 Error Code C-C136
  • MORGY
    • 38
    Hi Freinds
    Got the above error code after replacing the printer controller board. I checked the service manual and happen to find that it was a mismatch of firmware between the image controller and printer controller. Image controller version I1 and Printer controller P to be installed.
    The required firmware was downloaded and installed but the error code still remained. I then checked all connections and other boards and all were good.
    Has anyone come across similar fault and has had the chance to fix it?
  • wjurls
    • Feb 2017
    • 498
    Re: Bizhub PRO 951 Error Code C-C136
    Did you install level 51 image control (I ROM) firmware by chance? Level 51 is only for the 1052 and 1250. For 951 only install level 50 I Rom or you will get that error.
    Lee
    • kmcopytech
      • Dec 2007
      • 141
      Originally posted by MORGY
      Hi Freinds
      Hi.
      PRO951 does not support the SD-513. Do not install I-ROM to the PRO951.
      If applied, it causes unmatched version with P-ROM displaying SC code, C-C136.
      In this case, bring the I-ROM version back to the previous one (downgrade).
