Konica Minolta Bizhub C253 error C-DC00
  • Naveed Shahid
    • May 2008
    • 162
    [Error Code] Konica Minolta Bizhub C253 error C-DC00
    Hello Everyone
    Bizhub c253 Keep Showing C253 I Changed Already MFp Board But Still Same Error
    Any Suggestion
    Highly Appreciate
  • Synthohol
    Certified Konica Expert
    • 5749
    Re: Konica Minolta Bizhub C253 error C-DC00
    did you run the latest FW? did you select engine data restore?
    • Naveed Shahid
      • May 2008
      • 162
      • kmcopytech
        • Dec 2007
        • 141
        Check:
        1\coin vendor set.
        2\Scanner connection.
        3\Hdd.
        • Synthohol
          • 5749
          manual says security issue. did someone try to copy money even as a joke?
          try formatting the HDD?
          • Naveed Shahid
            • May 2008
            • 162
            I try to format hdd cant be able format any suggestion
            • Synthohol
              • 5749
              if it cant format, replace it.
              • Naveed Shahid
                • May 2008
                • 162
                i replaced hdd from running machine but still same position
                • Synthohol
                  • 5749
                  ok, can you boot into service mode and do a data initialization?
                  • Synthohol
                    • 5749
                    check your messages
                    • cayyell
                      • Feb 2013
                      • 82
                      Hi
                      any update regarding the issue? I m having the same code on C280
