bizhub 652 does not recognize a new toner cartridge
  • Laserbeam
    • Aug 2011
    • 152
    [Misc] bizhub 652 does not recognize a new toner cartridge
    Hello,
    yesterday, a customer called me, his bizhub 652 does not recognized a new toner cartridge. I tried again with another new cartridge, but the display still shows the message: "Toner is consumed. Replace toner as instructed".
    In Tech-Menu - Level History 1, TCR-K value is 0,00% !!!!!
    However, the printouts/copies where very good until the message "Replace Toner".
    A restart or trouble-reset did not change anything. The display shows the same message.
    Unfortunately printing or copying is not longer possible.
  • paulrid
    • Nov 2011
    • 206
    Re: bizhub 652 does not recognize a new toner cartridge
    Check the small plate where the chip on the toner presses against when inserted into the machine, there should be 3 pins sticking out which connect to the toner chip. I have seen these bent in or broken so the machine doesn't see the toner being inserted.
    paul.
    • Laserbeam
      • Aug 2011
      • 152
      Hello Paul,
      thanks for your fast reply!
      Yes, I checked these 3 pins. They are all visually fine and not damaged or broken. However, I didn`t remove these unit to examine it more closely. It seems that the toner cartridge chip is not recognized.
      But why is the TCR-K value 0,00% ??? Could it be the developing-unit?
      • paulrid
        • Nov 2011
        • 206
        Hi,
        i don't think the TCR level being at zero is the problem I've seen this when you get errors and until the machine prints something it shows zero. Have a look at the sensor check in tech rep and check the toner sensor, try removing and inserting the toners and see if they all show as should.
        paul.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4721
          Are you sure developer didn't dump? Very common on this machine.
          I would try latest firmware first.
          There are a few bulletins about toner not being recognized. Main thing was already mentioned about the pins that contact chip. Also about that small chip board being replaced.
          • Laserbeam
            • Aug 2011
            • 152
            At noon today, I renewed this sensor board (PN 4136765101) and all works fine!!!!!!!!!!!
            1000 thanks to you, copyman and paulrid!!! You've been absolutely right with your guess.
