K7145 scan to E-mail error code N61
+ More Options
Posts
  • kmcopytech
    • Dec 2007
    • 141
    The machine don't install the HD-103 Type-A!
    smtp port:25;
    pop port:110;
    smtp / pop server settings and utlook express the same!OE is OK...
    but scan to E-mail display N61 Can not connect to the network....
    How to Set???
    thanks!!!
  • TheOwl
    • Nov 2008
    • 1732
    It could be that you need a mailbox setup for the email address that you are using on the copier.
    Sometimes mail servers have the security setup so that you require a mailbox with your email address attached to authenicate the emails that you are trying to send.
    • kmcopytech
      • Dec 2007
      • 141
      NEED konica 7145 sevice manual,
      This problem has plagued me!!!
      smtp port:25;
      pop port:110;
      How to Set???
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Ensure the following:
        1. Default gate way is correct
        2. DNS is correct ( at a work station do an "ipconfig /all" enter all DNS addresses it displays + point DNS to the gateway)
        3. SMTP is correct
        4. Scan to Email is enabled
        5. Machine has a valid Email address Both machine address and key op address( make them the same )
        6. If the SMTP requires authentication, enter the authentication information under the POP setting and set to POP before SMTP
        If all of the above is correct and the address you are trying to send to is good, it should scan without issues. Provided of course there are not other things like firewalls and network rights restricting the copier.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • kmcopytech
          • Dec 2007
          • 141
          thank you very much!!!
          I went to try and at the same time thanks to redime!!!
