Bizhub C3850 Banding all colors
  • ChrisG
    • Oct 2013
    • 184
    Need some help guru's. All image components are new including IU's, ITB, Fuser, and transfer roller. Have stopped the copy/print half way through and the drums are all solid colored like they should be and it happens before the fuser. Like I said the ITB and transfer are new but is there any other common failings such as power packs or contacts that cause issues?
    All colors show same banding but doesn't seem to be a pattern
    Banding is heavier towards the front of the machine versus the rear
    This does happen on both internal prints and copies.
  • antonisp
    • Jun 2016
    • 8
    Re: Bizhub C3850 Banding all colors
    My best bet is transfer voltage problem.
    I am not familiar with the printer, but if your image on drums are ok next thing to check is image on belt.
    If that is ok too then probably it's a bad contact between machine and secondary transfer roller. Try cleaning it, check for bend contacts etc...
    Then your next suspect is power supply, High Voltage unit.
    I don't think it's fuser related...
    • Boltaction
      • 92
      Can't remember if the C3850 transfer belt assy's come with a new transfer roller or not. That's the one consumable left that I would suspect otherwise what's left is HVPS or bad contacts.
      • SmellsHot
        Head Tech
        • 512
        Just to clarify. You replaced all those parts after noticing the issue correct?
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • ChrisG
          • Oct 2013
          • 184
          Correct
          Customer had originally called for LCQ which is when the units were replaced. I believe the banding itself to be more severe and evident now versus just light copies
          All IU's are new, fuser ITB, and secondary transfer roller are new
          Have stopped the paper mid copy and it looks as though it's on the belt that way but it's hard to see for positive. It has already happened before the fuser. My suspicion is power pack but was hoping there was a more common "oh yea if you get that it's this" type of suspect.
          • SmellsHot
            Head Tech
            • 512
            Hv on the back would be the next logically step. Some sort of grounding issue
            • Sheshonq
              • Jun 2018
              • 10
              Cleaning the laser unit below the drum units.
              • lazymangr
                • Feb 2017
                • 115
                i had the same on a c203. more banding than this all colors. never found a solution after changing all of the consumables. drum belt etc. but the machine got 1mil prints
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  Looks to me like the second transfer roller isnt pressing evenly against the transfer belt.
                  this is the kind of effect you get on the 654 series when the rear transfer roller cam driven rocker arm snaps.
                  • AjitN
                    • Mar 2009
                    • 287
                    Even if right side door is not latching properly, it will give uneven density across width
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      I'm guessing this is the issue since this machine doesn't have a 2nd transfer retraction system. Taken from the manual
                      "In this machine, the 2nd transfer roller does not have a retraction mechanism, so that the transfer belt and 2nd transfer roller are pressed up against each other at all times."
                      Press in on the front side of the side door while in use, near where it latches and see if the issue goes away or improves. If so, the hook on the front that holds the door shut may be worn, damaged or broken.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
