Biz hub 3850f
  • antone
    • Oct 2014
    • 344
    Biz hub 3850f
    Error E301....did power reset...reset memory....anything 2 add?
    Sent from my SM-N920V using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Biz hub 3850f
    from the service manual, does not even list relevant parts to replace!!
    Trouble type
    Trouble code E301: Referring incorrect memory
    E302: Incorrect command
    E303: Finished due to error inside Qt library
    E304: Finished due to error outside Qt library
    E305: Program forced to stop
    Rank C
    Detection timing Received an error of irregularity.
    Trouble isolation -
    Relevant electrical parts -
    (2) Procedure
    1 Turn OFF the main power switch, disconnect and then
    connect the power cord. Wait for 10 sec. or more after
    connect the power cord, and turn ON the main power
    switch.
    2 If the above actions do not solve the problem, contact
    KM.
    • antone
      • Oct 2014
      • 344
      Re: Biz hub 3850f
      Trouble type
      Rank C
      Trouble isolation -
      (2) Procedure
      switch.
      KM.
      Special firmware update...took care of trouble code
