IP Address setting through service mode.
  • JacobAbrham
    • Jul 2017
    • 9
    [Misc] IP Address setting through service mode.
    Bizhub C550. I was trying to install firmware throught FTP method. Since the machine is on error, the administrative option is not available. Is there anyway to change the IP Address information of the printer through Service mode? Thanks
    Sent from my HTC One_M8 using Tapatalk
  • tech51
    • 846
    Re: IP Address setting through service mode.
    What error do you have? Does it show a code?
    • JacobAbrham
      • Jul 2017
      • 9
      C-C164. I wanna install a firmware with FTP but the machine IP setting is on Auto. I want to change that.
        • 14739
        C-C164 indicates the wrong model firmware has been installed. Simply write the correct firmware to your 128mb compact flash card and rewrite it to the machine. It shouldn't be any more difficult than that. The important part is making sure you have the correct model firmware.
