C250 Error Code C-2253
  • Stephanyie
    I have a Bizhub C250 that is displaying error code C-2253 "Malfunction Detected" It was working in the morning and then this code came up, don't know what happened...
  • alexxcopier
    • 53
    C2253 Color PC Drum Motor's failure to
    turn
    The Motor Lock signal remains HIGH for a predetermined
    continuous period of time while the
    Motor is turning.
    take Imaging units out and take a look for something wrong try to rotate drums
    • Stephanyie
      I looked at the imaging units, they look fine to me, but I don't really know what I am looking for... and what are the drums? How to I rotate them?
      • Stephanyie
        I also found that if I open the front of it and then close it, it resets for a second, it sounds normal for a second but then it clicks and it sounds like a fan goes on from the side of it by the bypass tray area and then the message comes back. Hope this helps you help me
        • RockETop
          Curmudgeon at large
          • Apr 2007
          • 171
          "Call the Man..." - Andy Taylor
          • JustManuals
            • Jan 2006
            • 9838
            Another one who didn't read the header:
            An online community for copier-printer and fax technicians
            Call one.
            • Stephanyie
              Sometimes you find help in odd places, thanks for the attitude instead of assistance, it is really productive I hope you feel awesome about yourself. And instead of calling a tech, I thought I would try this first, but I see how it is, you are a jerk... thanks alexxcopier for at least trying
              • alexxcopier
                • 53
                drums are green cylinders they have to be turned only in one direction but it is hard to explain here, so take them out /the fourth/ and try one by one to rotate maybe one of them is stuck or something i don't know
                better way is to observe and if you find something wrong go ahead, but if you did't find call a tech
                wish you luck
                • Stephanyie
                  Thank you- tech person came out today and found that the board and motor both were bad and needed to be replaced. About $1700 in parts alone, at least $500 in labor. Thanks so much for your assistance.
                  • ni311
                    • May 2008
                    • 658
                    too bad you're not a tech, you could win $2200
                    • RockETop
                      Curmudgeon at large
                      • Apr 2007
                      • 171
                      Gee. We were right. And no thank you.....
                      • redime
                        This is why you also dont buy a copier without a service contract
                        Especially something with 4 image units and a transfer belt
