Konica Bizhub C280 image Problem
  • mearmi
    • Oct 2010
    • 346
    Konica C280 getting vertical patch
    replaced all drums and transfer Belt.
    please find the attached image and advise
    thanks
    • 22927
    Re: Konica Bizhub C280 image Problem
    If that band is in the feed direction, It's magenta. Either a dirty laser slit glass, a bare spot on the developing roller, or possibly even dirty laser optics (internal optics). =^..^=
    • mearmi
      • Oct 2010
      • 346
      Thanks a lot.
      Replaced the Magenta Developer Unit as well but still same.
      For laser how can we clean it? Or we have to remove it from the copier?
      Regards,
      • joelea
        • Feb 2012
        • 64
        Originally posted by mearmi
        Thanks a lot.
        Regards,
        Under the drum is another cleaning rod that cleans the window of the PH unit.
          • 22927
          If the wand does not help, then yes, you must remove it from the copier. Keep in mind that painted screws indicate critical adjustments, and should not be touched. You don't have the proper equipment to re-align laser optics, so just clean, not disassembly.
          With a blank area as large as that you should have no trouble identifying the culprit.
          • mearmi
            • Oct 2010
            • 346
            Thanks please advise in details
            regards
            • furius
              • Jan 2018
              • 34
              Had the same problem on a C454 the problem was the faulty laser unit.
              Obviously it could also be an electronic board problem
