konica minolta c351 writes c2251 error
  • oluwatope333
    • Dec 2017
    • 9
    [Error Code] konica minolta c351 writes c2251 error
    hi everyone, i have read several posts about bizhub c351 but i really have this issue unfixed yet,
    my bizhub 351 konica minolta has been down for some times now, i have had to change the Cyan IU twice and i still have thesame issue, the cyan prints very faintly and writes c2551 error after printing about 5 sheets, i will really appreciate your support to solving this matter, thanks.
    Last edited by oluwatope333; 01-18-2018, 08:05 PM. Reason: i made a mistake with the headline please
  • copyman
    Owner / Technician
    • Sep 2005
    • 4736
    Re: konica minolta c351 writes c2251 error
    Are you sure the Cyan toner is adding? Is it genuine K/M toner? I would take the toner out and really shake well. Make sure opening where toner comes out is working properly. Also check toner motor.
    Go into service mode and check toner %, if low than look for a tab in service mode to add toner and see if level % rises.
    • oluwatope333
      • Dec 2017
      • 9
      Re: konica minolta c351 writes c2551 error
      i think i have tried out few things to put this through, i have cleaned the LPH assay, wipe cleaned the TCR sensor and even changed the developer. Is there any way to verify the compatibility of the toner from the machine, i got the toner from the store intact in its bag!
